• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise Wishes
    Distinguished Contributor
    Studio should be smarter with creating layers from SDF sources
    123 Views, 4 Replies
    07-25-2007 05:57 PM
    Because SDF can store multiple geometry types, when I create a new layer from a SDF feature source, the new layer will have all 3 geometry styles, even if the SDF only has one type of geometry.
    The only time a layer from a SDF feature source has a single geometry type style is if it was converted from a different format (eg. SHP)
    Studio should be smarter about this, it should figure out that there's only polygons in it and so if I create a new layer from it. It will only have polygon styles. Not all 3 together!
    Currently, the only way to change this is to manually edit out the useless styles in the layer document. And that is a time consuming process.
    - Jackie
    http://themapguyde.blogspot.com
    http://au.linkedin.com/in/jackieng
    Please use plain text.
    *Jason Birch
    Re: Studio should be smarter with creating layers from SDF sources
    07-25-2007 11:55 PM in reply to: jumpinjackie
    That's not necessarily true. SDF files contain a schema which, among
    other things, defines what kinds of geometry types are allowed in each
    geometry column. If you create an SDF class that limits the geometry
    column to a specific geometry type, then only that type will be
    displayed in Studio.
    How are you creating the SDF files?
    I found this to be a problem with FME2006, because it did not allow you
    to set the geometry type, but FME2007 does (you need to replace your
    destination data sets).
    Also, fdo2fdo allows you to do schema re-mapping, which I'm pretty sure
    includes changing the allowed geometry types.
    Jason
    Active Member
    08-16-2007 06:04 AM in reply to: jumpinjackie
    Even if it can be defined in SDF, this problem remains when you use other kind of datas:
    IE: the new "Oracle foreign datastore" feature in AMGE 2008 doesnt know what kind of geometry you have in the tables. the layer will have all 3 geometry style. The only method to prevent this is to export your layer as xml, the import it whit mapagent. That is not user friendly.
    Can't you add a checkbox or somewhat that can limit geometry style used on a layer on the creation?
    08-16-2007 06:57 PM in reply to: jumpinjackie
    The SDFs were created from Map3D 2008.
    Hmmm, on second thought this could be more of a Map3D problem, as it always produces an SDF with all 3 geometry types.
    And Studio is just simply interpeting that.
    This wish was probably for the wrong product XD
    - Jackie
    *Jason Birch
    08-21-2007 09:22 PM in reply to: jumpinjackie
    I agree that it would be useful to allow the users to select which
    geometry types to use for data sources that contain more than one
    geometry type (or which only contain one but aren't smart about exposing
    it). I'd like to see all stylization options presented with, as you
    say, checkboxes next to each to enable/disable them.
    Jason
