• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    *Andy Morsell
    Site corrupted - MG Server Fails to Start
    109 Views, 3 Replies
    11-18-2006 12:11 PM
    I had to reboot my Windows XP development laptop
    with MapGuide Enterprise SP1 installed today.  When it rebooted, the
    mgserver process was consuming 100% of the CPU and appeared the MapGuide Server
    service was trying to start but could not.  I confirmed this by looking in
    the services control panel and using pskill, psservice, etc. to try to get the
    service to start.  I finally gave up and completely uninstalled and
    reinstalled MG server and SP1.  After installation, the service started
    right up.  I then went into Administrator and changed the paths for
    everything to point to my Repositories location.  I then restarted the
    service to get the settings to stick, and the servivce would not start
    again.
    So, at this point, the problem has to be corruption
    in the repository somewhere.  Using the as installed Repositories folder, I
    discovered that if I overwrote my Site folder with it's Site folder contents,
    then the service would start.  So, it looks like somehow the files in my
    Site repository folder became corrupt and was preventing MG server from
    starting.  I have no idea how this happened, but it is rather
    disconcerting.  Luckily it was only the Site data that was a problem and
    that my Library seems to be fine.  Otherwise I would be reaching into my
    backups to restore from.
    Please use plain text.
    Employee
    Re: Site corrupted - MG Server Fails to Start
    11-20-2006 07:30 AM in reply to: *Andy Morsell
    The Site repository contains the Users/Groups and related settings for an MG Site. For this to get corrupted is odd. I believe it is possible to delete everything from below the Site folder when the MG Service is stopped. Upon restarting the Server will recreate the required files for the Site. In fact this is also true for the Library subfolder as well. This at least is less work than a full reinstall. However you will have lost any custom users and groups that were created. Restoring from backup is the way to go. Although I've never seen this happen I would highly recommend anyone creating more than 2 or three users and groups to backup their Site repository using the backup mechanisms in the RepositoryAdmin folder.
    Dave
    Dave Wilson
    SQA Analyst
    AEC IM
    Autodesk, Inc.
    *Andy Morsell
    11-20-2006 08:45 AM in reply to: *Andy Morsell
    Thanks Dave. I just tried deleting all of the files in the Site folder and
    they were indeed rebuilt when the service was started again. The users were
    then set to default, as you noted, but I was pleased to see that the the
    Resource Service paths were preserved - so that information must be stored
    elsewhere. I agree that it is odd for these files to become corrupted, but
    my trouble-shooting definetely led to this being the problem. One thing to
    note, when the reboot occurred, it was an automatic restart triggered by a
    Microsoft Office update.
    Andy
    wrote in message news:5401584@discussion.autodesk.com...
    Dave
    Employee
    11-21-2006 01:01 PM in reply to: *Andy Morsell
    If a situation occurs as noted by Andy let the service fail to start. From a command prompt attempt to start the mgserver in interactive mode "c:\....\mgserver.exe /interactive". It may be that a recover of the repository is being attempted and it may take longer than the time allotted for a Windows Service. If successful the mgserver should eventually start in interactive mode. If so then stop it and attempt to restart the Windows Service.
    Dave
    Dave Wilson
    SQA Analyst
    AEC IM
    Autodesk, Inc.
