• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Valued Contributor
    Server not available Error
    600 Views, 4 Replies
    11-28-2012 08:08 AM
    Hi there,
    Recently AIMS 2013 always popup this error(see below image). But the map still there, all the functions still work after you click the "OK" below.  Can anyone help me with this?
    Please use plain text.
    Valued Contributor
    Re: Server not available Error
    11-30-2012 09:16 AM in reply to: swimming123
    I also check the error log, it shows following information:
    <2012-11-30T10:07:07>     3532    Fusion Viewer    ::1    Administrator
     Error: An exception occurred in FDO component.
            Unable to resolve the host. Host not found.
     StackTrace:
      - MgFeatureServiceHandler.ProcessOperation() line 83 file d:\build\ims2013\build_52.8\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
      - MgOpGetIdentityProperties.Execute() line 112 file d:\build\ims2013\build_52.8\ent\os\server\src\services\feature\OpGetIdentityProperties.cpp
      - MgServerDescribeSchema.GetIdentityProperties() line 1261 file d:\build\ims2013\build_52.8\ent\os\server\src\services\feature\ServerDescribeSchema.cpp
      - MgServerDescribeSchema.DescribeFdoSchema() line 278 file d:\build\ims2013\build_52.8\ent\os\server\src\services\feature\ServerDescribeSchema.cpp
      - MgFdoConnectionManager.Open() line 334 file d:\build\ims2013\build_52.8\ent\server\src\common\manager\FdoConnectionManager.cpp
      - MgFdoConnectionManager.CacheFdoConnection() line 1059 file d:\build\ims2013\build_52.8\ent\server\src\common\manager\FdoConnectionManager.cpp
      - MgFdoConnectionManager.Open() line 1051 file d:\build\ims2013\build_52.8\ent\server\src\common\manager\FdoConnectionManager.cpp
    The error happens when the server is busy or when you leave the browers without any operation. Why host not found. Do I need to set up something? Thank you.
    Valued Contributor
    12-11-2012 11:17 AM in reply to: swimming123
    I found this problem only happens for IE; Firefox and Chrome don't have this problem.
    12-11-2012 05:47 PM in reply to: swimming123
    You are probably using IIS correct?
     Turn off all security on the IIS virtual folder except for Anonymous (I.E. is sending the user)
    Valued Contributor
    12-12-2012 08:46 AM in reply to: gluckett
    Yes, I use IIS.  Turn off all security is not  Turn off the Authentification, right? Becaue I have to leave Anonymous and Forms Authentification on (for user log in).
