• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    wilsonherrera
    SQL SERVER SPATIAL COORDINATES FLIP
    1359 Views, 3 Replies
    08-13-2012 09:56 AM
    currentlky i have several layers stored in MS SQL server 2008 if i query them inside sql server management studio, the layers appear normal, but one i try to load them into mapguide, the x and y values swap, creating a 90° map.
    this would be a nice feature if you could enable with a click, but this is a bug, and a big one to start, this mean that i can´t really load data from a MS SQL Spatial.
    is there a way to fix this? this also happens in map 3D.
    this is the layer in MS SQL SERVER
    this is mapguide
    Please use plain text.
    Re: SQL SERVER SPATIAL COORDINATES FLIP
    09-12-2012 07:20 AM in reply to: wilsonherrera
    workaround: store ll coordinates in geography rather than geometry
    wilsonherrera
    10-09-2012 01:04 PM in reply to: gluckett
    its a workaround but it works! thank you!
    12-05-2012 10:01 AM in reply to: wilsonherrera
    This BUG has no HOTFIX and is STILL Broken with the FDO 3.7 for the following products:
    • MapGuide Open Source 2.4
    • Autodesk IMS 2013
    • AutoCAD Map 3D 2013
    • Autodesk Infrastructure Modeler 2013
