• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Valued Contributor
    Redline export/import posiible in AIMS2013
    556 Views, 2 Replies
    12-13-2012 01:20 PM
    In mapguide2011, we save redline as .gml file. Since in AIMS2013, we save redline as a .sdf file which is a SQL Server Compact Edition of Database File, I cannot open this file in Visual Studio2010. Upload a saved redline file to the map is useful in reality.But I noticed no matter how features I draw, all the sdf files are all same size(350kb).My question is how can I save and upload this file to my map? Probably I didn't do the correct steps. Thank you.
    Please use plain text.
    Re: Redline export/import posiible in AIMS2013
    12-13-2012 07:01 PM in reply to: swimming123
    SDF != SQL Server Compact database
    SDF = Autodesk Spatial Data File. ie. The defacto flat-file spatial data format in MapGuide/AIMS
    This is what the redline widget is saving your redlines as, so the same downloaded redlines can be loaded into something like AutoCAD Map with simple drag/drop.
    - Jackie
    Valued Contributor
    12-17-2012 08:14 AM in reply to: swimming123
    Probably download redline function not work, upload readline not exsit in AIMS2013.
