• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide Enterprise
    Platform - .NET vs PHP
    77 Views, 3 Replies
    01-29-2007 11:46 AM
    I develop in asp (not .NET), yet I've had very little experience with VB.NET.
    I've seen php and its somewhat similar to asp - simple coding.
    I'm torn - what platform to go with. I am with a local Government - somewhat of a Microsoft Shop.
    Will php last? Any unbiased positions on php vs .net? Which has more options and functionality for the end user and integration with other systems?
    Please use plain text.
    *Andy Morsell
    Re: Platform - .NET vs PHP
    01-29-2007 02:28 PM in reply to: bcales
    Take a look at http://www.tiobe.com/tpci.htm for popularity rankings of
    various languages. The big difference between the languages is that .NET
    requires that you are running a Microsoft Server and using Internet
    Information Servies. PHP and Java are platform independent. Also, PHP is
    free and open source; .NET is not. PHP is easier to learn and write in
    since it tends to be used in a linear, procedural manner similar to what you
    are probably doing in ASP right now. ASP.NET (and Java) are more difficult
    to learn since they are object oriented languages from the ground up.
    Personally, I prefer writing in C#.NET, but PHP is probably the most
    universal solution. In most cases, these decisions should be dictated by
    your internal IT department's standards.
    Andy Morsell, P.E.
    Spatial Integrators, Inc.
    http://www.SpatialGIS.com
    wrote in message news:5467542@discussion.autodesk.com...
    VB.NET.
    *Jason Birch
    01-29-2007 05:40 PM in reply to: bcales
    From personal experience, in some municipalities these standards can be
    flexible if there is a good cost/benefit reason for bending them :smileyhappy:
    Our internal standard is to use .Net for web development (VB.Net or C#).
    However, I'm pushing PHP for MapGuide-related development. Partially
    because I'm fluent in it, but also because I believe that there are
    long-term benefits to going with PHP.
    Here are some points in favour of PHP:
    - It's easy to learn
    - It's installed on the MapGuide server by default (it's required by the
    server administration application)
    - It's easier to get support from the MapGuide Open Source community on
    language-specific issues (more PHP users than C#/Java)
    - Most of the developer samples are in PHP
    - I think that it is a reasonable guess that in the long run more
    community-developed code will be available for PHP
    The real answer though is to use whatever language is the best fit for
    your organisation's infrastructure and your developers' abilities.
    Jason
    *Mateo
    01-30-2007 01:15 AM in reply to: bcales
    PHP is very popular and it will last... Problem with PHP is that is not
    object oriented language... PHP can run on both platforms, MS, and
    Unix-alike platforms. .NET technology is, no question, the best internet
    programming platform ever. And it becomed even better in 2005 version! It
    takes maybe little more effort to learn .Net, but once you have, it is much
    easier and faster development than PHP. I'm not against a PHP, I have used,
    PHP, ASP 3.0, Asp.Net 2003 and 2005 with VB and C#, and I found .Net
    platform the best platform ever... Plus, it have the best integrated
    development environment!
    VB.NET.
