• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide Enterprise
    New Member
    DesM
    PHP page 404 Error
    378 Views, 1 Replies
    01-09-2011 01:07 PM
    I have installed Mapguide 2011 server on Windows 2008 R2 64-bit and the Web Extensions on the IIS6 web server on W2003 64-bit using the 64-bit versions of both.  Our application uses a combination of .Net 1 and 2.
    Application pools have been used for the different .Net versions with Mapguide using the .Net 2 App Pool.
    Try as I might I cannot display any php pages there show 'page not found' (404) errors.
    PHP runs from the command line processing a text file to echo some text.  I have tried a test.php file to show phpinfo() in various locations but nothing shows.
    One inconsistency I have noticed is that within the IIS GUI manager the .php extensions are registered OK but running ADSUtil show scriptmaps does not return any php mappings.
    Any help would be much appreciated
    Please use plain text.
    Employee
    Re: PHP page 404 Error
    01-13-2011 09:42 AM in reply to: DesM
    Have you tried a phpinfo() page?
    It may be you need to add php to your system path.
    Is there any other version of PHP installed?
    Dave
    Dave Wilson
    SQA Analyst
    AEC IM
