• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Valued Contributor
    MyByteReader to Stream Reader
    600 Views, 6 Replies
    11-09-2012 01:19 PM
    Can I get the data from MgByteReader, and turn to Stream Reader; so I can make a pdf map using iTextSharp?
    Please use plain text.
    Re: MyByteReader to Stream Reader
    11-11-2012 06:27 PM in reply to: swimming123
    You can try this class I wrote, that provides a System.IO.Stream adapter over the MgByteReader:
    http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Desktop/MapViewer/MgReadOnlyStream.cs
    - Jackie
    Valued Contributor
    11-13-2012 12:20 PM in reply to: jackie.ng
    Thank you Jackie,
    when I add your class to my project, I found I cannot reference the namespace OSGeo.MapGuide.Viewer; And Line 216 "Strings" not exist in the context. I am pretty new, can you help me more? Thanks again.
    Valued Contributor
    11-13-2012 05:43 PM in reply to: swimming123
    Did I need other assembly class files?
    11-13-2012 06:47 PM in reply to: swimming123
    That file can't just be dropped in, so change/rename the namespace
    Strings.ErrorStreamNotRewindable is just a localizable message, just replace it with something equivalent
    - Jackie
    Valued Contributor
    11-13-2012 07:13 PM in reply to: swimming123
    I create a new class file and paste your code there, but still I cannot new a MgReadOnlyStream. I cannot find the problem is.
    Valued Contributor
    11-14-2012 07:28 AM in reply to: jackie.ng
    Finally I get the MgReadOnlyStream. Thank you Jackie.
