• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Valued Contributor
    Measuring tool in AIMS2013 NOT stop by double click.
    558 Views, 4 Replies
    11-29-2012 02:16 PM
    I found measing tool does't stop by double click. It is annoying bug.
    Please use plain text.
    Re: Measuring tool in AIMS2013 NOT stop by double click.
    11-29-2012 06:00 PM in reply to: swimming123
    Double click works. I'm guessing it just has a very low tolerance making most double clicks not register
    - Jackie
    Valued Contributor
    11-29-2012 07:28 PM in reply to: jackie.ng
    It works on FireFox, not IE for me. I don't know how to fix this if it's because of tolerance. Thank you Jackie.
    Member
    Betreff: Measuring tool in AIMS2013 NOT stop by double click.
    11-30-2012 08:26 AM in reply to: swimming123
    Questions:
    1) Which version of IE do you use?
    2) If IE 9: Are you running IE in Compatibility mode?
    3) What is the language of your operating system (OS)?
    Things I've noticed:
    - Double click works fine in IE 9 (without Compatibility mode), Firefox, Chrome and Safari.
    - It doesn't work on IE 7 and IE 8.
    - In IE 9 it doesn't work if you have enabled the Compatibility mode.
    Also I've noticed that some functions doesn't work proper on a non-English OS.
    However (as a workaround) 'SHIFT + left mouse click' works with all browsers (even IE 6).
    System: MapGuide Open Source 2.4 as well as AIMS 2013 with Apache on Windows Server 2012 (German OS)
    - Bernhard
    Valued Contributor
    11-30-2012 09:08 AM in reply to: bernhard.maehler
    Yes, it works without compatibility mode. Thank you for the information.
