• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Active Member
    Markup example for Mapserver 2012
    482 Views, 4 Replies
    10-15-2012 07:12 AM
    Good Day All!!! Has anyone tried to use the sharable markup example (I believe it was call gt.zip) that came out a few years ago with Mapserver 2012/2013?? I had downloaded this for use with Mapguide Enterprise 2009 and it worked great for what I was doing, but doesn't seem to work with Mapserver2012. I don't get any error messages, and I'm sure with the change to Mapserver there was some coding changes, but I was hoping someone has had success getting it to work, or using something similar for sharable markups. Thanks!!
    Please use plain text.
    Valued Mentor
    Re: Markup example for Mapserver 2012
    10-17-2012 04:08 AM in reply to: howard.thompson2
    Don't forget to make an authoring user in the administrator.
    Markup - markup
    for username and password
    make sure your layout logs in with this user when you open the layout
    Active Member
    10-31-2012 01:13 PM in reply to: gluckett
    That was certainly part of my problem...I'm close to having this...but I'm getting an error listed below out of the Mapserver log files:
    <2012-10-29T09:36:02>  4832 Ajax Viewer 140.139.196.103 Administrator
     Error: Failed to stylize layer: _howard33333
            The coordinate system initialization failed.
            Could not initialize the geodetic transformation.
    I'm creating shp files and dwf files using Autodesk Map. I believe it doesn't like the coordinate system, but I've tried different ones to no avail.
    Valued Mentor
    10-31-2012 01:17 PM in reply to: howard.thompson2
    Yes, the definition of LL84 has changed (this is true for MGOS 2.4 too)
    I had this issue before, find how I fixed it here:
    http://osgeo-org.1560.n6.nabble.com/API-Change-in-MG-2-4-tt4996684.html#a4997139
    Active Member
    11-01-2012 05:59 AM in reply to: gluckett
    That did work for me!!! Thanks alot!!!!! One last question...this only works for data with a true coordinate system doesn't it?? I have some data that I published, but becasue it wasn't in a true coordinate system, I used the arbitrary XY-FT when I published my data, and the markup tool doesn't seem to work on that...but I have other data, with true coordinate systems, and it appears to work on that just fine.
