• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Member
    Maptip to change into image gallery
    380 Views, 4 Replies
    04-05-2012 12:57 AM
    I am trying to create a Image gallery inside the map. when i click on the MapTip Layers, an image gallery window should popup. Is it possible to activate a hyperlink from Maptip. Please suggest me some ideas. Thank you.
    Please use plain text.
    Re: Maptip to change into image gallery
    04-05-2012 09:40 PM in reply to: DEVR1930
    Hey,
    I think you can find useful info here:
    http://themapguyde.blogspot.com/search?q=tooltips
    Valued Contributor
    pg002a
    04-09-2012 11:32 AM in reply to: DEVR1930
    Member
    04-09-2012 06:00 PM in reply to: sroussev
    thank u all :smileyhappy:
    Member
    04-12-2012 12:17 AM in reply to: DEVR1930
    Is it possible to implement Auto Re-Size Maptip i.e. When the user resizes the map browser window the embedded viewer will also resize and the background of the Viewer should be translucent.And Maptip viewer should cover about 90% of the display map area. i try to edit maptip.js file inside fusion/widget folder. But then i dint get any result when i change the folder.
    can a Maptip gallery be implemented by these requirement?
