• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide Enterprise
    *gom
    Mapguide Studio and DWG
    150 Views, 6 Replies
    10-10-2006 11:42 AM
    I am receiving a "dbx cas 4" error when I try to set up a data load
    procedure for DWG in Sutdio 2007. This happens as or after it has lodaed
    the DETE components. I repaired the install but no change.
    Any ideas as to what may be wrong?
    Please use plain text.
    Active Contributor
    Re: Mapguide Studio and DWG
    10-12-2006 09:35 AM in reply to: *gom
    This may indicate a corruption of some of the DLLs installed by Studio.
    Instead of using the "repair" option, try this:
    1. Exit the MapGuide Studio application
    2. Use the Window Task Manager to make sure that the DETE.exe process is not running. If it is, kill it.
    3. Uninstall MapGuide Studio.
    4. Go to the MapGuide Studio installation folder and delete any files and folders that did not get removed by step 3.
    5. Reinstall MapGuide Studio.
    Bill
    *gom
    10-12-2006 10:31 AM in reply to: *gom
    I tried that and it still gives the same error. I do have Map 3d 2007
    installed on the same machine. I wonder if there is any chance that this
    causes some confilcts with DLLS?
    wrote in message news:5359810@discussion.autodesk.com...
    Bill
    Active Contributor
    10-13-2006 07:12 AM in reply to: *gom
    If you install both Map 3D and Studio, there should be no DLL conflicts.
    Here are some things to check:
    Make sure that you are installing a recent (1.0.0.17804 or later) version of MapGuide Studio. I recall that old (pre-release) versions of MapGuide Studio had this problem.
    Look at your computer's Path environment variable. If for some reason this variable is including folders that contain Map 3D DLLs, then this might be the cause.
    Bill
    *gom
    10-13-2006 08:32 AM in reply to: *gom
    The version is 1.0.0.17804. It is the shipping product installed from the
    Autodesk CD. Nothing is on the path.
    wrote in message news:5360915@discussion.autodesk.com...
    the cause.
    Bill
    Active Contributor
    10-14-2006 02:14 AM in reply to: *gom
    It might help to know if the problem is data-related. You could try creating an empty DWG file and try loading it into Studio.
    Bill
    *gom
    10-15-2006 04:14 PM in reply to: *gom
    No difference.
    I installed studio on another box and it worked fine.
    wrote in message news:5361837@discussion.autodesk.com...
    Bill
