Autodesk MapGuide Enterprise
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
MapGuide Studio 2007 und Mapguide Server 1.0.1 - is ist possible?
Options
- Highlight
- Email to a Friend
190 Views, 7 Replies
08-24-2006 03:02 AM
is it possible to use MapGuide Studio 2007(1.0.0.17804) and MapGuide Server (open source) 1.0.1 together?
Because some fixes I'd like to use the new version of MapGuide Server. So I have uninstalled MapGuide Enterprise and installed MapGuide Server + Extensions from open source. But the studio did not find the server. What is wrong?
Thanks in advance - Peter
Re: MapGuide Studio 2007 und Mapguide Server 1.0.1 - is ist possible?
Options
- Highlight
- Email to a Friend
08-26-2006 08:18 AM in reply to:
Peter65
Hi Peter,
Yes, version 1.0.0.17804 (which is the commercially released version) of MapGuide Studio 2007 is fully compatible with MapGuide Open Source Server and Web Extensions version 1.0.0 and 1.0.1.
If you are not able to get Studio to connect to the server, you can try these steps to help determine the cause:
1. Enter a URL like this into your web browser: http://servername/mapguide/mapagent/index.html or http://servername
ort/mapguide/mapagent/index.html. The result should be a web page that has a list of service APIs in the upper left, starting with "Resource service API".
2. If step 1 above does not work, check to ensure that the mgserver.exe process is running, and the your web server process is running. If step 1 above does work, then check the spelling of the site adress that you are supplying to Studio.
Bill
Bill
Options
- Highlight
- Email to a Friend
08-28-2006 04:34 AM in reply to:
Peter65
Hi Bill,
thank you very much. Yes, it works :-). I suppose, that my IP-adres was false.
Peter
Peter
Options
- Highlight
- Email to a Friend
02-14-2007 02:46 PM in reply to:
Peter65
From your reply
------------------------000000000000-------------- --------------
Is this (as I imagine it is) compatible with MapGuide Open Source Server and Web Extensions version 1.1.0.
When trying to login I get:
The Studio version is incompatible with the site version.
I tried the SP1 (mg7_studio_sp1.exe) which did not go smoothly.
Reported error 1328, that file C:\Config.Msi\pt7d.tmp could not be patched. ..... Contact your patch vendor.
I am using the studio in the 'free 60 days mode'
Any help on this would be much appreciated,
Ivar
Ivar
*James Card
Options
- Highlight
- Email to a Friend
02-14-2007 03:18 PM in reply to:
Peter65
A patch for this is available at <>
https://mapguide.osgeo.org/downloads.html#links-1. 1.x >.
James Card>
James Card>
Options
- Highlight
- Email to a Friend
02-14-2007 05:09 PM in reply to:
Peter65
Thanks James for your reply,
Don't seem to see the patch name in your reply.
We are talking VERSION
MapGuide Open Source 1.1.0
I hope,
Thanks for any help,
Ivar
I hope,
Ivar
*James Card
Options
- Highlight
- Email to a Friend
02-14-2007 05:13 PM in reply to:
Peter65
If you have an evaluation version of Studio, you will need to do the
following:
Download the new Autodesk.MapGuide.Studio.Site.dll from <>
http://download.osgeo.org/mapguide/patches/mapguid estudio/1.1.0/Autodesk.MapGuide.Studio.Site.Patche dDLL.zip
> (md5: 58aa5c890ad91e7df34801e54abf25d8).
Unzip the file to the Studio install location.
Once the patch is installed, Studio will be able to communicate with both
1.0 (MapGuide Enterprise or MapGuide Open Source) and 1.1 servers.
James Card>
following:
James Card>
Options
- Highlight
- Email to a Friend
02-15-2007 12:19 AM in reply to:
Peter65
Many thanks James, once again, if you cannot read, you have these problems. Looking more closely at http://mapguide.osgeo.org/downloads.html you see exactly what you suggested.
Extract:
Note: The released MapGuide Studio will disallow connecting to the MapGuide Open Source 1.1 server with a "The Studio version is incompatible with the site version" error dialog. To resolve this issue use one of the following methods:
If you have a licensed version of Studio download and install the patch (md5: cde783d5207ec22d11fcc185825fde72). The patch will work on both the released and SP1 versions of Studio 2007. (If you overwrote the Autodesk.MapGuide.Studio.Site.dll file for RC1 and need to get the original file back, it is available here md5: 92839a0fc3b87541f23adaf4d836f2ed.)
If you have an evaluation version of Studio, you will need to do the following:
1. Download the new Autodesk.MapGuide.Studio.Site.dll from here (md5: 58aa5c890ad91e7df34801e54abf25d8).
2. Unzip the file to the Studio install location.
Once the patch is installed, Studio will be able to communicate with both 1.0 (MapGuide Enterprise or MapGuide Open Source) and 1.1 servers.
It works just as you said,
Many thanks again, and now for some EXCITING testing
Ivar
PS Have been working and developing with MG since its birth a few years back now and 'What a product'
Thanks again!
Extract:
Ivar
Thanks again!
