• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    cpietra
    Map Display issue Using MobileViewer
    389 Views, 5 Replies
    10-12-2012 07:02 PM
    Initial Map display on ipad iphone very small and does not follow initial display sale size as set in Mapguide Studio.
       More importantly as zooming into map, at a partiular scale everytime all layers turn off. All layers are set in studio to remain on at all scales. Map initial display is set to within extents. Is there something I need to modify in html filr or related.
    Thanks ahead of time
    Please use plain text.
    Valued Mentor
    Re: Map Display issue Using MobileViewer
    10-17-2012 04:05 AM in reply to: cpietra
    the map extents are very important to all layouts and the mobile viewer.
    i would recommend downloading the latest Maestro and using the tool to collect the extents from all layers in the current map. to find it, just open your map.
    i wish this tool was in studio.
    cpietra
    10-17-2012 04:11 AM in reply to: cpietra
    Gordon
    I have played with the extents in studio 2013 but it does not seem to make any difference.  I get Parse errors or the map displays way out and zooming in causes all layers to turn off.  Different maps may not load at all , just spin indefinitely.  One map is down to a single parcel layer. No dice.  By the way I still have the Cold Fusion T shirt from the Autodesk training in Virginia around 1998 MapGuide 6.0 from the class you taught
    Valued Mentor
    10-17-2012 04:15 AM in reply to: cpietra
    ah, remember that class. love cold fusion still.
    i had trouble adding any map not in spherical mercator. are your maps in that?
    cpietra
    10-17-2012 04:35 AM in reply to: cpietra
    No   State Plane NAD 83 NY Central    Do you have a link to current Maestro ?
    Valued Mentor
    10-17-2012 04:40 AM in reply to: cpietra
    i would try spherical mercator (google projection) first.
    maestro
    http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
