• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Member
    MGE 2010 flexible viewer too slow
    257 Views, 5 Replies
    09-09-2009 02:05 PM
    when using MapGuideEnterprise 2010 and flexible layouts - this
    is very slow (legend widget) and IE7 just freeze for 5-15s ( IE8 also bad,
    FireFox is little better) because of huge Java Script work (100% of client processor).
    This is problem on client with Javascript code ( method UpdateLayer()
    called so many times ). The server side is ready and works fine!
    Our enterprise project is approx 150 layers sorted in tree, the layers have legends
    with less than 5 styles, only 20 layers has legends with 20 styles.
    It has beed combined to minimum number of layers according the custome
    The problem is, that flexible layout - every time when changing zoom -
    rebuilds completely the layer tree very,very,very inefficient way
    Is there any solution how to speed up this - or - some optimalization
    not to rebuild not-expanded groups/layers etc. ? Will be this solved
    in next version or will be published some patch ?
    Thanks Edited by: ondrejnovotny on Sep 9, 2009 11:16 PM
    Please use plain text.
    Employee
    Re: MGE 2010 flexible viewer too slow
    10-06-2009 09:21 AM in reply to: ondrejnovotny
    Increase the memory_limit setting in your php.ini to something like 256M. This may help improve things.
    Dave
    Dave Wilson
    SQA Analyst
    AEC IM
    Autodesk, Inc.
    Member
    10-29-2009 05:50 AM in reply to: ondrejnovotny
    Thanks for answer, but is has nothing to do with described problem.
    The problem is described in very detailed way in original post
    and is situated in Javascript Fusion code.
    Employee
    10-29-2009 08:13 AM in reply to: ondrejnovotny
    I understand your post, but I have seen an 800 layer map with a lot of themes perform acceptably simply by increasing the php memory limit. Yes the legend redraw behaviour is less than optimal I agree, but I'm not seeing things pin as you describe.
    I believe I have seen postings in the OSGeo Commuminty discussing improvements to this behaviour, but I am not aware of a specific time frame for implementation.
    Dave
    Dave Wilson
    SQA Analyst
    AEC IM
    Autodesk, Inc.
    *Jason Birch
    11-09-2009 08:23 PM in reply to: ondrejnovotny
    Indeed. It's a known problem, but not an itch for any of the primary
    developers as far as I know because they're not creating 150-layer maps.
    One way to have this fixed would be to pay an open source Fusion
    developer to spend some time on the problem, but depending on the
    optimal solution I suspect that some MapGuide changes may also be
    required. There are some core developers that can work in both MapGuide
    and Fusion, but they are rare.
    Jason
    Member
    11-11-2009 02:40 AM in reply to: ondrejnovotny
    Thanks for answers.
    Currently in productuion enviroment we've changed the code in way,
    that legends with more than 10 styles does not display and
    are replaced with one manually prepared fixed image. It is
    a little work, but usable. Than, the client performace was accepted.
