• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise Developer
    Active Member
    Re: Layer - URL Activated for Feature
    01-04-2007 11:20 AM in reply to: bhenning
    I have attached the functions that I added to the propertyctrl.templ to load a page inside a custom frame when a map object is clicked.
    In addition you may want to add the code to close the streamreader in the LoadTemplate function in the common.aspx page or you will have issues replacing the templ file:
    Please use plain text.
    Active Member
    01-04-2007 12:13 PM in reply to: bhenning
    Hi Thanks for getting this . let me try this right away
    thanks in million
    T
    Active Member
    01-05-2007 02:19 PM in reply to: bhenning
    Brandon,
    thank you for the information.
    "For the loop through all of the selected polygons using the MapGuide API", which MapGuide Document shows the decent example?
    Many thanks,
    Perry
    Active Member
    01-05-2007 02:30 PM in reply to: bhenning
    Perrry,
    Autodesk MapGuide Enterprise 2007 Developers Guide on page 47 (Chapter 3 - Working With the Active Selection).
    The example is in PHP but I was able to convert it to C# without any major issues.
    Brandon
    Active Member
    01-05-2007 07:21 PM in reply to: bhenning
    Brandon,
    Many many thanks for this info! I will put it to good use.
    Cheers Perry
    New Member
    lihao5000
    04-19-2011 05:11 PM in reply to: bhenning
    Hi I have use URL Activated Feature funtion , it is fine, However, recently , I have layer which contains 20 attributes , I want tio capture all those attributes , but this function only allowed me capture 11 atrributes . Any way I can capture ( Ctr and Click)  more then 11 attributs?
