Autodesk MapGuide Enterprise Developer
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Infrastruc ture Map Server 2013 on Windows Server R2 Standard
- Highlight
- Email to a Friend
- Report Inappropriate Content
The system requirement for the above product as shown in the document
System Requirements (64-bit)
Operating System
• Server components: Windows Server® 2008 Enterprise, Service Pack 2 (SP2)
Question: is there a difference if the product is installed in Windows Server 2008 R2 Standard?
Re: Infrastruc ture Map Server 2013 on Windows Server R2 Standard
- Highlight
- Email to a Friend
Windows Server® 2008 Enterprise is the officially supported OS, but I expect it runs on Windows Server 2008 Standard as well, although is it not officially supported.
Daniel Du
Developer Technical Services
Autodesk Developer Network
- Highlight
- Email to a Friend
Hi Daniel,
Is Infrastructure Map Server2013 will still work for Windows Server 2003 R2 standard?
We also use IIS6 as our services? will still run?
Buddy
- Highlight
- Email to a Friend
Hi Buddy,
AIMS 2013 is only tested on the OS which is described in the system requirement document, it may run on other OS, but please note that it is not officially supported.
I personally did not try Windows Server 2003 with IIS6, so I have no say about it, I tried on Windows7, it works, of cause it is not suitable for production environment.
Hope this clarifies.
Daniel Du
- Highlight
- Email to a Friend
Hello SIr,
Good day! We would like to inquire for technical documents or manual for installing Web Server extensions and Several
Site Servers on different separate servers, also the configuration on how to load balance the multiple site servers.
Thank you very much.
- Highlight
- Email to a Friend
This site should be helpful:
especially this page for load banlancing
http://sandbox.mapguide.com/index.php/Pragmatic_Lo
Daniel Du
- Highlight
- Email to a Friend
Sir,
Good day! We have already done what is written on the following:
but unfortunately load balancing does not work, the load is only focused on one server. Maybe you have
some further details.
Thank you.
- Highlight
- Email to a Friend
Hello Sir,
Good day! We would also like to know the proper server sizing for AIMS 2013 in terms of single server (Web and MapServer on one machine) and also for separate server setup, in pragmatic mode.
Thank you.
