Autodesk MapGuide Enterprise
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
IMS 2012 install issues
- Highlight
- Email to a Friend
I've just done a fresh install of Infrastructure Map Server 2012 64-bit version 2.3.0.4202 on two different machines that had never had Autodesk products on them before. One is running Windows Server 2008 R2 Standard 6.1.7600. The other has Windows Server 2008 Standard, 6.0.6002. Both have IIS 7.5. We are still awaiting new license numbers, so they are running the 30-day trial. I'm a new Autodesk user but a pretty experienced GIS guy.
The installation seemed fine, and I followed the instructions for configuring the web extensions for IIS 7.x (here, and I incorporated the advice in the comments at the bottom). All of the verifications (here) checked out okay, and I can use the web-based Site Administrator (at http://localhost/mapserver2012/mapadmin/login.php
But in Infrastructure Studio, when I try to connect to the site URL (tried both http://localhost/mapserver2012 and http://127.0.0.1/mapserver2012), I get "Cannot connect to the specified site URL."
When running the Web Tier Tests at http://localhost/mapserver2012/mapagent/index.html
I suspect something is amiss in the IIS configuration, but who knows. I'm not an IIS expert myself, but I've got others here in the office who can help me with that. Just checking here to see if anyone else has experienced this. It's basically a show-stopper, as I can't get beyond square one in Infrastructure Studio until this gets solved.
Re: IMS 2012 install issues
- Highlight
- Email to a Friend
Okay, now when I use the port number 8088 in the URLs (eg. http://localhost:8088/mapserver2012/mapagent/index
- Highlight
- Email to a Friend
I'm getting the same error "Cannot connect to the specified site URL". However, the solution above doesn't fix mine. I've also tried ports 8008, 80, and 8088.
Does anyone know what's causing this issue?
Here are my system specs:
Windows 7 64bit Professional
IIS (version 7.5.7600.16385)
I am also an Admin on my machine.
Support Specialist
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
- Highlight
- Email to a Friend
As per in the previous post the 32/64 bit issue is that the MapServer2012AppPool / Advanced Setting / General / Enable 32-bit applications SHOULD BE SET to FALSE, not TRUE as shown in the image.
- Highlight
- Email to a Friend
