• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Valued Contributor
    How to use fusionSF.js functions
    411 Views, 1 Replies
    10-24-2012 12:47 PM
    Hi there,
     fusionSF.jsis a big file, it includes lots of functions, so how to use these functions in my new widget? How to understand this file? for example, try to use drawPoint method, it accept 3 parameters geometry, style, featureId;  then how can I define the geometry just based on x, y and coordinates system such as EPSG:4326?
    I can upload a file to draw many points on a exsiting map using OpenLayers, but how to do similar job in AIMS2013 Fusion Viewer? Thank you.
    Please use plain text.
    Valued Mentor
    Re: How to use fusionSF.js functions
    11-01-2012 07:02 AM in reply to: swimming123
    There is limited value here:
    http://trac.osgeo.org/fusion/wiki/Documentation
    but Daniel's blog is really good for API:
    http://adndevblog.typepad.com/infrastructure/daniel-du/
    And if you want MapGuide Open Source help, check out Jackie's:
    http://themapguyde.blogspot.ca/
