• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Valued Contributor
    How to use Fusion API for creating points layer
    285 Views, 0 Replies
    10-18-2012 03:01 PM
    How to create points in the client side by input lonlat values? I try use following code:
               var mgApiMapWidgetId = 'Map';
                var MainFusionWindow = GetFusionWindow();
                var pointsLayer = MainFusionWindow.OpenLayers;
                var Fusion = MainFusionWindow.Fusion;
                var mapWidget = Fusion.getWidgetById(mgApiMapWidgetId);
                var map = Fusion.getWidgetById(mgApiMapWidgetId).oMapOL;
                alert("a");
                pointsLayer.LonLat.fromString("51.2356, -114.235689");
                alert("aa");
                map.addLayers([pointsLayer]);
                alert("aaa");
    It can alert to "aa". That means last step not success. Do I need add SRS from the current map? Thank you.
    Please use plain text.
