• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    *Meng Li
    How to load a huge set (about 3.5 gb) of ecw images outside the default install dir for MGE?
    9 Views, 4 Replies
    11-21-2006 09:34 PM
    My default install of MGE(server and Web tier) is on C drive with 3 gb free
    space and now I want to set up a layer of orthophotos in ECW with a total
    size of 3.5 gb (170 ecw files). I know I can not load the ecw files into the
    repository of the default install on my C drive simply because of the space
    limit and a max of 2 gb limit for a package file through Studio.
    If I don't want to change my default install (to d drive which has 150 gb
    space) now, how could I make the ecw files of 3.5 gb as a feature source in
    MGE repository but pointing to a file folder having the 3.5 gb ecw files on
    my d drive? I read about this workaround for SDF and SHP files:
    https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=321
    I tried the method suggested with this content text file:
    xmlns:xsd="http://www.w3.org/2001/XMLSchema"
    xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
    Autodesk.Raster.3.1
    DefaultFileLocation
    D:\orthophotos\1-6000-ECW
    ReadOnly
    TRUE
    But it seems this setup via Admin still needs to load the ecw files from d
    drive to the c drive repository in order to make them available for a layer,
    which means this method does not work for me.
    Packaging the 3.5 gb ecw files failed too because of the 2gb limit for this
    process even though with Admin I could reconfigure the package dir from c to
    d drive.
    Do I have any other workarounds than reinstalling the server repository to d
    drive in order to overcome the space limit problems for big image files?
    Meng
    Please use plain text.
    *Andy Morsell
    Re: How to load a huge set (about 3.5 gb) of ecw images outside the default install dir for MGE?
    11-21-2006 10:35 PM in reply to: *Meng Li
    Hi Meng,
    Did you follow the steps in this white paper?
    http://images.autodesk.com/adsk/files/linking_to_external_data_autodeskmapguidewhitepaper.pdf
    There is also a Request for Change (RFC) currently underway for MapGuide
    Open Source that pertains to this topic and that change would then in turn
    make it into a future MapGuide Enterprise release.
    http://wiki.osgeo.org/index.php/MapGuide_RFC_2_-_Unmanaged_Data_APIs
    Andy
    "Meng Li" wrote in message
    news:5403707@discussion.autodesk.com...
    Autodesk.Raster.3.1
    DefaultFileLocation
    ReadOnly
    TRUE
    d drive.
    Meng
    *Meng Li
    11-21-2006 11:33 PM in reply to: *Meng Li
    Hi Andy, thanks for the reply. I didn't read the whitepaper before but
    believe that the method is similar. Will have a look at the doc. after my
    posting I did successfuly repoint my ecw path to the d drive and can display
    the 3.5 gb ecw files as a layer (not a base map layer) but the performance
    wasn't good enough. The performance for displaying the same ecw orthophotos
    layer (using a RIC file) with MG 6.5 is very good, so we expect MGE could
    give us a similar performance.
    Yes, I read the RFC pertaining to the topic and hope it can be available as
    planned.
    Thanks again for the help and will meet with you at AU.
    Meng
    "Andy Morsell" wrote in message
    news:5403729@discussion.autodesk.com...
    Hi Meng,
    Andy
    Autodesk.Raster.3.1
    DefaultFileLocation
    ReadOnly
    TRUE
    d drive.
    Meng
    *Meng Li
    11-22-2006 01:01 PM in reply to: *Meng Li
    I tried to link my ecw raster data (3.5 gb with 160 files) on d drive with
    the method in this whitepaper:
    But when testing the connection for the feature source in Studio, I got this
    error:
    Permission denied to resource:
    Session:df377bc2-ffff-ffff-8000-00145e299cd0_en//FeatureSourceEditorsScratch/SessionVersion1.FeatureSource
    I found it's difficult to list all my 160 ecw files in the configuration
    document with the configuration xml document allows me to use a wild card for names of
    features and images from a defined image file dir? Any better tool like
    Raster Workshop is available for doing this kind of work?
    I am still unable to create a raster layer to display my recent ecw
    orthophotos of 160 files for the entire city with MGE.
    Any other suggestions?
    news:5403742@discussion.autodesk.com...
    planned.
    Meng
    Hi Meng,
    Andy
    Autodesk.Raster.3.1
    DefaultFileLocation
    ReadOnly
    TRUE
    d drive.
    Meng
    *Meng Li
    11-23-2006 04:52 PM in reply to: *Meng Li
    I got it working and the error was related to some incorrect formats in the
    xml doc. I found that using the Migration Tool migrating the MLF file can
    allow me to create the xml configuration document (config.xml) with the
    config template and all image file names populated, with this config.xml
    file, I successfully created a raster feature source pointing to the ecw
    files directory on D drive of my MGE server.
    news:5404683@discussion.autodesk.com...
    error:
    planned.
    Meng
    Hi Meng,
    Andy
    Autodesk.Raster.3.1
    DefaultFileLocation
    ReadOnly
    TRUE
    d drive.
    Meng
