• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Active Member
    Hover Over Feature - Null Shows Up
    356 Views, 9 Replies
    03-07-2012 01:00 PM
    Hi Everyone,
    Please help....
    I'm running into a bunch of issues upgrading to 2012 from 2010... and here's another one I'm hoping someone has seen before and can help me out.
    I have set Tooltips for all my features on my map, so when you hover over something it will tell you what it is...
    However, for all of my features and all my tooltips there is a Null value showing up right at the top of the tooltip window.  I attatched a screen shot of what happens.  All the lines of the tooltip will show up, however the Null is always visable, how can I correct this?
    Heidi Hinz
    Please use plain text.
    Re: Hover Over Feature - Null Shows Up
    03-08-2012 11:15 PM in reply to: Heidi03
    What does the Tooltip expression in your Layer Definition look like?
    - Jackie
    Active Member
    03-09-2012 05:34 AM in reply to: jackie.ng
    Thanks Jackie... Here's a screen shot of my layer.  It's just simply calling an attribute field named C_NAME...
    Active Member
    03-10-2012 09:53 AM in reply to: Heidi03
    I noticed that my tooltips do this when I switch over to the turquoise/yellow layout in AIMS 2012.
    Active Member
    03-10-2012 09:55 AM in reply to: elbison
    There is usually a little spec of something (like a single quote) up top in the other layouts (where null is showing up in T/Y).
    Active Member
    03-12-2012 04:55 AM in reply to: elbison
    I'm looking for a quote or something out of the ordinary, but I'm not sure if I'm looking in the right place?  Where is "up top"?  I'm very new to this and at a beginner level....  Thanks.
    Active Member
    03-12-2012 05:06 AM in reply to: Heidi03
    I bet the other layouts just have the word "null" realllllllllly tiny.  Can you switch to another layout briefly to confirm?
    Active Member
    03-12-2012 05:15 AM in reply to: elbison
    Yes, it looks like its in the "Industry Extension Aquq" layout too...
    Valued Mentor
    03-19-2012 06:38 AM in reply to: Heidi03
    Yes, this is an old bug.  Has been propagated for a number of versions.
    http://osgeo-org.1560.n6.nabble.com/Tooltip-with-null-value-with-Fusion-Internet-Explorer-tp4184779p...
    Active Member
    03-25-2012 10:33 AM in reply to: gluckett
    I found that if I switch from Internet Explorer (my work uses 8) to Firefox, this and a couple other issues go away.
