• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Active Member
    Highlight selected MySQL objects
    119 Views, 6 Replies
    10-01-2006 12:21 PM
    Hi @all,
    and thanks for creating this group :-).
    Here my first question. Sorry for cross post (OSGeo) but the following problem is unsolved:
    I've loaded geometry objects from MySQL database. The connection to the database is possible. Also the geometry is shown. But when I select one line, all lines of the layer are highlighted. Interesting is, that the tooltip works correctly.
    Here is a code example for inserting the lines into MySQL:
    insert into tra_strasse_geometrie(strageo_geo, strageo_name_id) Values (geomfromtext('linestring(4531094.71 5686671.65,4531027.17 5686674.21)'), 7);
    The table "tra_strasse_geometrie" is of MyISAM type and the row "strageo_geo" is of type GEOMTERY with index.
    I'm using MySQL 5.0.24, MGOS 1.0.1, MG Studio 1.0.0, AJAX viewer.
    Sorry, but I'm new with MGE and MySQL too.
    Thanks in advance.
    Regards - Peter
    Please use plain text.
    Active Member
    Re: Highlight selected MySQL objects
    11-27-2006 05:07 AM in reply to: Peter65
    Hi @all,
    after installing SP1 for the studio and using MGOS 1.0.2, a part of the problem is solved. But only a part: selecting an object leads to highlighting it.
    But now I have an other problem. The selection is sometimes not correct. I want say, moving the cursor over one object, the tool shows the information of an other object an select and highlight the other object.
    Can anybody help?
    Thanks in advance - Peter
    *James Card
    11-27-2006 10:55 AM in reply to: Peter65
    Probably not much help, but we have a dataset that exhibits similar
    behavior. The zoom-to function zooms to and selects the correct feature,
    but the report in the Properties pane displays data for an adjacent
    feature (which always has a key value that is one greater or less than the
    key for the selected object).
    This can be seen at < ="">, do an address
    search (for "1040" as an example) and then zoom to various parcels in the
    result set. For example, zooming to 1040 Monterra Ln produces a report for
    1119 DeMoll Dr.
    James Card
    Active Member
    11-28-2006 12:28 AM in reply to: Peter65
    Thanks for reply. What FDO are you using. I ask, because I have this behavior with MySQL. When I use the same geometry from shape-files, then it works fine.
    Best regards - Peter
    *James Card
    11-28-2006 08:58 AM in reply to: Peter65
    > it works fine.
    Data was originally shapefiles, but we had MapGuide Studio convert it to
    SDF when it was loaded into the repository.
    James Card
    Active Member
    11-29-2006 12:32 AM in reply to: Peter65
    With shapefiles I had no problems (exported from Autodesk MAP). Only with MySQL.
    However I found a first solution :-). Yesterday I installed the dwf-viewer and it works fine :-)!!! Perhaps this could help you too?
    02-20-2008 03:08 AM in reply to: Peter65
    i think till now you will beccome master in mysql and mapguide studio and data connectivity bt i don't know anything about connectivity ,please guide me .what is procedure of data connection
    thanks
