• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    wilsonherrera
    Google Message inside Mobile Viewer - General Google Maps overlay
    1151 Views, 5 Replies
    09-06-2012 02:39 PM
    Hello everyone.
    i am experiencing a trouble with a message from google maps everytime i interact or load  a google maps basemap.
    if i zoom, the message appears, if i move, the same issue.
    this happens with AIMS 2013 bot in mobile and desktop web clients.
    is there a fix for this?
    thank you for your Help
    W. Herrera
    Please use plain text.
    Re: Google Message inside Mobile Viewer - General Google Maps overlay
    09-06-2012 08:35 PM in reply to: wilsonherrera
    Assuming that viewer is using OpenLayers 2.11, just patch the library like so:
    https://github.com/openlayers/openlayers/commit/92f04a7a4277a6c818ef2d40a2856910ed72d3d6
    or like this
    http://trac.osgeo.org/openlayers/wiki/Release/2.11/GoogleMaps37
    - Jackie
    09-12-2012 07:19 AM in reply to: wilsonherrera
    wilsonherrera
    10-09-2012 01:01 PM in reply to: wilsonherrera
    thanks for the quick response! the fastest way to fix this problem was with the solution Gordon Posted.
    after a while i tested Jackie solution and this also works!.
    thank you very much.
    Wilson H
    New Member
    11-09-2012 08:06 AM in reply to: wilsonherrera
    Hello Everyone,
    The solution works well on IMS2013 desktop environment, but I cannot remove the google popup window from MobileViewer Extension.
    Someone does it work?
    Thanks for advance,
    Tamas
    11-11-2012 06:51 PM in reply to: katonat
    It's probably using its own version of OpenLayers that needs to have the same patch applied
    - Jackie
