• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide Enterprise Developer
    Valued Contributor
    Fusion customization
    999 Views, 3 Replies
    05-22-2012 04:09 PM
    Hi there,
    I am new to use map server infrastructure. How can I learn to do customization in fusion? Any book or something I can buy? Thanks.
    Please use plain text.
    Re: Fusion customization
    05-23-2012 07:52 PM in reply to: swimming123
    What exactly are you trying to customize?
    Look and feel? Hack and play around with the css/html of one of the fusion templates
    Functionality? Create your own InvokeURL and InvokeScript widgets, and add them into your Flexible Layout
    - Jackie
    Valued Contributor
    05-23-2012 09:08 PM in reply to: jackie.ng
    Hi Jackie I want to create a widget for this task: cusomter click on the map for any specific location, my function can query several hundred of layers and create a report for cutomers. So customer can based on the report to make a decision. Easy to use spatial data instead of reading my hundred of layers and their attribute values behind. So this task has several steps: - create a layer resource for the point of interest; - doing the query between new point layer and my exsiting layers; - Response.Write the results in a format like table; Pretty tough for me because I am beginner. Can you help me with this task. Thank you.
    ADN Support Specialist
    05-24-2012 02:18 AM in reply to: swimming123
    Have you ever checked this DevTV on Infrastructure Map Server developer center?
    DevTV: MapGuide Fusion Technology Introduction
    A self-paced video tutorial on how to build a web-based mapping application using the Fusion Viewer Technology and MapGuide Enterprise.
    View Online | Download
    Daniel Du
    Developer Technical Services
    Autodesk Developer Network
