• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Active Member
    Exercises in Autodesk MapGuide Enterprise 2011 Getting Started Guide
    625 Views, 2 Replies
    11-19-2012 03:24 AM
    I'm using Autodesk Infrastructure Studio 2013 (v2.4.0.5208) and I;m working through the exercises in the Autodesk MapGuide Enterprise 2011 Getting Started Guide using the Sheboygan sample data.  When I attempt the exercise to connect to an Access database everyhting appears to go fine until I click on 'Test Conncetion'.  I then get an error message :
    An exception occurred in FDO component.
    RDBMS: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
    What am I doing wrong?
    Please use plain text.
    Re: Exercises in Autodesk MapGuide Enterprise 2011 Getting Started Guide
    11-20-2012 05:34 PM in reply to: tony.witham
    If this is 64-bit MapGuide/AIMS, then the ODBC driver name may be different
    - Jackie
    Product Support
    11-22-2012 07:36 AM in reply to: tony.witham
    If you are on a server, or system without Office, you might not have any drivers at all.  http://www.microsoft.com/en-us/download/details.aspx?id=13255 will set you up with what you need.  Be sure to match the bit-ness of Map Server.
    Nate Moore, GISP
    Geospatial Premium Support Specialist
    Global Services
    Autodesk, Sarl
