• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise Developer
    Error when using "OSGeo.MapGuide" in C# file
    1254 Views, 6 Replies
    02-20-2007 01:07 AM
    iam getting error when i tried to compile
    my code behind file (C#) file
    that
    "OSGeo.MapGuide" namespace not found
    but when i import namespace in asp.net page
    using import "OSGeo.MapGuide"
    no error comes n page run successfully
    why this is so?
    if i want to use "OSGeo.MapGuide in my cs file
    why iam getting error....
    i copied both dll mapguidedotnetapi.dll n maguidenammaged ...dll
    to my application bin directory...
    sheetal
    Please use plain text.
    Distinguished Contributor
    Re: Error when using "OSGeo.MapGuide" in C# file
    02-22-2007 03:53 PM in reply to: rush.sheetal
    There's extra unmanaged dependencies in OSGeo.MapGuide.
    Try copying every dll in the bin directory of the mapviewernet folder
    Cheers,
    Jackie
    http://themapguyde.blogspot.com
    http://au.linkedin.com/in/jackieng
    02-24-2007 12:28 AM in reply to: rush.sheetal
    I copied all file ...
    stiil error comes in cs file..
    New Member
    06-01-2007 10:15 PM in reply to: rush.sheetal
    hi,
    i am using mapguide, but i am getting getting error saying missing directive. OSGeo.MapGuide. even though i have imported that namespace in aspx page.
    Member
    07-01-2007 03:30 AM in reply to: rush.sheetal
    Probably the AcMapApiMgd.dll is missing in reference..
    raghulan
    09-25-2012 09:12 PM in reply to: velan
    Hello just incase someone needs the info..
    that dll that contains the OSGeo.MapGuide;
    Autodesk.Map.Platform.Core.dll
    Cheers
    Raghulan Gowthaman Cert IV TAA, B.E,.
    Senior Civil BIM Consultant | Geo Spatial - IT Specialist
    CSI Global pty Limited. - Singapore | Sydney
    Web : www.csigs.com.au
    www.civil3dforum.com | www.e4forums.com
    ADN Support Specialist
    10-31-2012 10:27 PM in reply to: raghulan
    Autodesk.Map.Platform.Core.dll and AcMapApiMgd.dll are part of Map 3D, not MapServer(AIMS or MapGuide).
    You probably forget to convert your virtual directory to web application in IIS.
    Daniel Du
    Developer Technical Services
    Autodesk Developer Network
