Autodesk MapGuide Enterprise Developer
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Error - Could not load file or assembly MapGuideDo tNetAPI
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm trying to embed an AIMS 2012 viewer in a webpage. I'm following the instructions in Daniel Du's webcasts. It doesn't matter if I embed a basic layout or a flex layout. I get the same error message when I try to browse the page - "Could not load file or assembly 'MapGuideDotNetApi, Version=2.3.0.4202, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format."
I found some references to this error on the OSGeo website for MapGuide OS but not sure if it applies to AIMS 2012. I know that the dll referenced in the error message is only used for backwards compatibility. Since this is a brand new web app, I'm not concerned about backwards compatibility. So I thought I could just remove the offending dll from my website "bin" folder. But then I get the same error message, except now it references one of the new OSGeo.MapGuide dlls.
Has anyone come across this? Anybody know how to fix it?
Re: Error - Could not load file or assembly MapGuideDo tNetAPI
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It's most likely a 32-bit/64-bit problem. One of these things doesn't match:
- You are using 64-bit MapGuide dlls from a 32-bit web application or vice versa
- Your web application is configured to be 32-bit in IIS, but using 64-bit dlls or vice versa
- Jackie
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Jackie,
Could you elaborate on how to determine which is which
- Jackie
- How can you tell what DLLs (64 or 32 bit) you are using?
- How do you determine what your application is configured for?
- When would you want to configure your application for 64 bit? Like what should it be if we are running MapGuide OSGeo 64 bit on Windows 2008 R2 Server?
- This final question depends a little on your previous answer: Where do we get the drivers once we know what we need?
Sierk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This video may be helpful for you.
Video : Autodesk® Infrastructure Map Server 2012 API Webcast
Recorded version of the Autodesk® Infrastructure Map Server 2012 API webcast
View Online | Download
Daniel Du
Developer Technical Services
Autodesk Developer Network
