• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Distinguished Contributor
    Does AIMS support UCS setting?
    459 Views, 1 Replies
    12-12-2012 07:04 AM
    Hi
    I would like to change the true north to specific angle! Can I do that? Thanks.
    Eric
    Please use plain text.
    Valued Mentor
    Re: Does AIMS support UCS setting?
    05-22-2013 12:47 PM in reply to: Cadbeyond
    That is a good question.  You will notice the rotation works great in the "Quick Plot" so why not the whole map?
    I think when FUSION/Flexible Web Layouts move to OpenLayers 3.0 (http://ol3js.org/ol3/master/examples/rotation.html?q=rotate)
    How I have done it in the past with MapGuide 6.5 and older was with the Oblique Stereographic Snyder Variation.
    This has an asimuthal that you can use to rotate the map.  It works great - just change the coordinate system to the ones you need.
    The trick is, creating the coordinate system (luckily AutoCAD Map 3D is a great tool for doing this).
    gordon
