• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Valued Contributor
    Create a map image for Fusion
    398 Views, 0 Replies
    11-09-2012 08:05 AM
    When I use API to create a map image, I use the MgRenderingService. If you use fusion, then I found pass paramters of extent is just create a data scale (not the view extent) and image is not same with your zoom level; So we need to pass map center coordinates, scale parameters to create a map image which is same with the view of your map. Share this information.
    Please use plain text.
