• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide Enterprise
    s.klein
    Connecting to PostGIS 2.0
    335 Views, 4 Replies
    01-26-2012 07:35 AM
    i want to connect the AIMS 2012 to a PostgreSQL-DB with PostGIS 2.0 installed.
    In Autodesk Infrastructure Studio i'm able to make a data connection so that the schema shows up in the preview.
    When i create a layer, no geometry is shown up in the preview...
    With Desktop-GIS like ArcMap or QGIS i can establish a connection without problems, so i think geometry columns are right in PostgreSQL 8.4/PostGIS 2.0.
    Has anybody solved a problem like that yet?
    SK
    Please use plain text.
    Re: Connecting to PostGIS 2.0
    01-26-2012 05:43 PM in reply to: s.klein
    The FDO provider that comes with AIMS 2012 does not support PostGIS 2.0
    - Jackie
    s.klein
    01-26-2012 10:43 PM in reply to: jackie.ng
    sorry to hear that...
    will fdo support postgis 2.0 in the nearer future?
    Active Member
    pian2000
    03-19-2012 01:16 AM in reply to: s.klein
    when you make the data connect can you view the attribute? and also when ceating for layer are you able to select the field?
    s.klein
    03-19-2012 02:41 AM in reply to: s.klein
    yes, i'm able to view the attributes and i can select the different attributes creating a layer... but the layer doesn't show up in the preview or weblayout. with postgis 1.5.3 it's working well.. i think aims can't handle the geometry cause it's stored in postgis 2.0 on an other way then in 1.5.3 and fdo doesn't support the postgis 2.0 geometry yet...
