• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Member
    Can IMS or Mapguide Enterprise 2011 be run on Server 2008 R2 Enterprise Core?
    183 Views, 1 Replies
    08-05-2011 11:13 AM
    I want to know if I need to do a full & complete install of Server 2008 R2 Enterprise, or if I can reduce the size of it by using the Core version, that reduces the size dramatically.
    Please use plain text.
    Re: Can IMS or Mapguide Enterprise 2011 be run on Server 2008 R2 Enterprise Core
    08-11-2011 07:15 PM in reply to: kshaeta
    All it would demand (I assume) is that IIS and .net Framework is installed, if you choose to go with this particular install configuration
    Does Server 2008 Core provide this?
    - Jackie
