• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Accepted Solution
    AIMS 2013 on LINUX with Oracle
    727 Views, 2 Replies
    12-05-2012 10:57 AM
    Hi All,
    I have a copy of Linux (Centos 5) and I have AIMS 2013 running.
    I can load and view files (i.e. MR SID/ECW/SDF/SHP)
    but when I try to connect to Oracle, I get an error:
    "The remote server returned an error: (559) MgFdoException.: An exception occurred in FDO component. Failed to retrieve Oracle error message."
    I have 32bit Oracle etc and the Oracle 32bit Client files are in the FDO library folder.
    Actually, the new Oracle data source dialog in Studio was greyed out until I did this on the server.
    I can connect everywhere else (even SQL Developer) but for some reason the FDO can't get to Oracle?
    Any tips?
    gordon
    Please use plain text.
    Valued Contributor
    ro_fr
    Re: AIMS 2013 on LINUX with Oracle
    12-05-2012 10:54 PM in reply to: gluckett
    Hi Gordon,
    not sure about 32bit/64bit Centos / AIMS - but I suppose Oracle client and application (AIMS) should both be either 32bit or 64bit - but not mixed.
    Is there any further information in aims error log file?
    If not - maybe GVC_TRACE_FILE helps to find out more. Have a look at:
    http://geospatialfrance.typepad.com/geospatialfrance/2007/12/activer-le-mode.html
    Good luck,
    Rob
    12-06-2012 06:31 AM in reply to: gluckett
    I figured it out (2 things)
    1. I had to install the Full Oracle Client (32bit) Administrator version and copy the SO files into the LIB folder of FDO.
    2. I had to download the 3.7 CentOS 5.5 Linux SDK and copy the so files that are missing in the Linux install of AIMS 2013 for Linux.
    that did the trick, I can now connect to Oracle with my Centos box with AIMS 2013.
