• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide Enterprise Developer
    cpietra
    AIMS 2013 Mobile Viewer issue
    844 Views, 1 Replies
    10-11-2012 07:40 PM
    Initial Map display on ipad iphone very small and does not follow initial display sale size as set in Mapguide Studio.
       More importantly as zooming into map, at a partiular scale everytime all layers turn off. All layers are set in studio to remain on at all scales. Map initial display is set to within extents. Is there something I need to modify in html filr or related.
    Thanks ahead of time
    Please use plain text.
    ADN Support Specialist
    Re: AIMS 2013 Mobile Viewer issue
    01-22-2013 09:54 PM in reply to: cpietra
    Are you still having this problem?
    For mobile viewer, you do not need to edit anything except the defaultMapDef value in index.html, which enable you to use your own map defination.
    Daniel Du
    Developer Technical Services
    Autodesk Developer Network
