• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    Valued Contributor
    nik.mazreen
    AIMS 2012 vs 2013 feature label function
    650 Views, 2 Replies
    10-30-2012 12:07 AM
    Hi all,
    I'm having difficulty when using Feature Label function in AIMS 2013 where the label will show as "Text" in the map preview although there is no info on the selected feature. see figure below - AIMS 2013)
    AIMS 2013
    It works find in AIMS 2012 where it should show any label on the selected feature because there is no info. (See figure below - AIMS 2012)
    AIMS 2012
    i'm not sure how to explain this but i hope u guyz could understand.
    thx
    -Nik-
    Please use plain text.
    Valued Contributor
    nik.mazreen
    Re: AIMS 2012 vs 2013 feature label function
    10-30-2012 08:49 PM in reply to: nik.mazreen
    Problem solved. I use : NullValue(property, replacement_value_if_null)
    Valued Contributor
    nik.mazreen
    10-30-2012 08:50 PM in reply to: nik.mazreen
