• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Enterprise
    *Meng Li
    A problem for both viewers with MGE SP1
    104 Views, 3 Replies
    11-08-2006 12:15 PM
    We are happy to see that MGE SP1 is greately improved with better stability
    and performance.
    However, a probem (seems to be a refresh issue) we noticed before MGE SP1
    still remains: with the AJAX viewer for sample or our own applications or
    Web layouts, the map in many cases turns blank (a blank background) without
    any error in every second action of some functions, e.g. for Find Parcel of
    Tasks, click on one link parcel, the map zooms to it and display, but a
    second click on another parcel link makes the map turn blank, a thir click
    on a parcel will bring the map display back again, etc.
    With the DWF for sample or our own applications or Web layouts, an initial
    load as well as every second action of a function always triggers a MapGuide
    Server error window saying "MapGuide Server Error: status code 559
    MgConnetionFailedException". Just click OK button to ignore it would still
    allow us to go on. Is it something that could be related to the sample
    application setup?
    Meng
    Please use plain text.
    Employee
    Re: A problem for both viewers with MGE SP1
    11-10-2006 09:38 AM in reply to: *Meng Li
    What webserver are you using? It may be related to the fastcgi settings found in the http.conf for Apache or under hkeylocalmachinesoftware\FASTCGI for IIS. You might try changing the killinterval for Apache. For IIS you might try increasing the idletimeout.
    Dave
    Dave Wilson
    SQA Analyst
    AEC IM
    *Meng Li
    11-10-2006 03:55 PM in reply to: *Meng Li
    I am using Win Server 2003/IIS 6. I saw a 'timeout' name under
    hkeylocalmachinesoftware\FASTCGI, but how to change the tiemout to what
    value, the current value data is '3c' .
    Thanks for the reply.
    wrote in message news:5392553@discussion.autodesk.com...
    Dave
    Employee
    11-14-2006 08:49 AM in reply to: *Meng Li
    When using regedit and you see hex values like this you can click the button to change the value to decimal. Then edit it as decimal. 3c = 60 seconds.
    Dave
    Dave Wilson
    SQA Analyst
    AEC IM
