Autodesk MapGuide Developer
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
zoomToScal e after Search
- Highlight
- Email to a Friend
- Report Inappropriate Content
When I use the search widget [Map Server 2012 (v 2.3.0.4202)], the selected item will be in the map window with zooming into its size.
The widget uses the following function for it (in the fusion/widgets/search/search.templ file):
function CellClicked(sel)
var map = GetParent().Fusion.getMapByName(mapName);
map.setSelection(sel, true);
}Tath's fine, but after it, I'd like to zoom the map scale to e.g. 1300, like this way:
map.zoomToScale(1300);
}But this is not good, because the setSelection is calling AJAX requsets. When does The existing zoomToScale() function need to run, when the response is ready or when the map status is ready? Or need another function instead of the setSelection() function? To modify the core (fusionSF-compressed.js) is a little bit difficult for me.
Any suggestion?
best regards,
Csaba
Re: zoomToScal e after Search
- Highlight
- Email to a Friend
I’ve found a solution for my problem. Originaly, my target was not just see the selected item,
but the environment. So I modified the GetSelectionProperties.php and the SaveSelection.php.
Because the extent of the object is calculating in this scripts, so I increased the extent.
best regards,
Csaba
- Highlight
- Email to a Friend
Can you describe what you exactly chnaged in those files?
- Highlight
- Email to a Friend
I have modified the extent properties of the result object (lower left and upper right coordinates). If the search result is a small object, the map will be in the minimum scale factor is 1, then you will see nothing in the map and need to zooming manually. It is not so comfortable.
In the \fusion\layers\MapGuide\php\SaveSelection.php you can find this part (before):
$result->hasSelection = true;
$result->extents = NULL;
if($getExtents)
$featureService = $siteConnection->CreateService(MgServiceType::Feat ureService);
$oExtents = $selection->GetExtents($featureService);
if ($oExtents)
$oMin = $oExtents->GetLowerLeftCoordinate();
$oMax = $oExtents->GetUpperRightCoordinate();
$result->extents->minx = $oMin->GetX();
$result->extents->miny = $oMin->GetY();
$result->extents->maxx = $oMax->GetX();
$result->extents->maxy = $oMax->GetY();
}After (in my case, the minimum width is 70 then the scale factor will be approximately 1000):
if($getExtents) {
if ($oExtents) {
$oWidth = (($oMax->GetX())-($oMin->GetX()));
$oHeight = (($oMax->GetY())-($oMin->GetY()));
if ($oWidth < 70) {
If ($oWidth > $oHeight) {
$oWidth = 70;
$oHeight = 50;
else {
$oWidth = 70;
$oHeight = 70;
$result->extents->minx = ($oMin->GetX())-2*$oWidth;
$result->extents->miny = ($oMin->GetY())-1.5*$oHeight;
$result->extents->maxx = ($oMax->GetX())+2*$oWidth;
$result->extents->maxy = ($oMax->GetY())+1.5*$oHeight;
- Highlight
- Email to a Friend
Thanks, really works!
