• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    Valued Contributor
    widget not display in the Toolbar
    981 Views, 3 Replies
    06-05-2012 09:18 AM
    I try to create a JS, xml file and copy to the right location under fusion/widgets folder; Added the widget into ToobarVertical, but the widget did not show. Probaly something wrong. Anyone can give me some suggetion?
    Please use plain text.
    Re: widget not display in the Toolbar
    06-05-2012 07:16 PM in reply to: swimming123
    Did you declare the appropriate widget in your the WidgetSet portion of the Flexible Layout document?
    - Jackie
    Valued Contributor
    06-05-2012 07:37 PM in reply to: jackie.ng
    I just use the InvokeURL widget (js and xml) and modified it. because I need create a point layer using OpenLayer, then pass the lot/lat value of point to server side and do the query. So I delete the selection part, binded the digitize a point function with the widget. I didn't check the WidgetSet part in ApplicationDefinition file. Is this the right way?
    Active Member
    lrodriguez84
    07-02-2012 11:29 AM in reply to: swimming123
    Hi, i did something similar. I created a widget to invoque js from this i did a http request to server and the server side (C#.net) response the result that i wanted.
