• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    Valued Contributor
    what's the API function for distance query
    922 Views, 1 Replies
    07-26-2012 08:04 AM
    Hi there,
    MapGudie has MeasureGreatCircleDistance(coord1, coord2) and MeasureEuclideanDistance(coord1, coord2) to calculate the distance between 2 points. What if I want to query the shortest and longest distance between one point and one layer which has one million points? Is there any API I can use? What's the solution I can use? Thank you
    Please use plain text.
    ADN Support Specialist
    Re: what's the API function for distance query
    08-27-2012 02:10 AM in reply to: swimming123
    Unfortunately, there is no APIs for topology like finding shortest path in MapGuide, you need to implement yourself.
    Daniel Du
    Developer Technical Services
    Autodesk Developer Network
