• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk MapGuide Developer
    Active Contributor
    create SDF
    71 Views, 0 Replies
    06-03-2008 03:57 AM
    Hi, following general question "how to do?".
    Using pure AutoCAD 2008 on client (workstation) side and MGOS 2.0 on server side I want to create SDF files for MG server from the current loaded DWG in AutoCAD. This creation must be callable via API (without dialog for user interaction).
    What is the recommended way for that task?
    - I don't want to use the MGStudio API (Enterprise version).
    - I can't use Autodesk Map 3D.
    Should the SDF be created on client or server side?
    Getting polyline information using VBA from current loaded DWG is done.
    On MG server Java/JSP will be used.
    Peter
    Please use plain text.
