• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    *Giovanni
    append new objects to sdf file
    120 Views, 4 Replies
    06-14-2005 03:00 AM
    hi
    i need to append new object to a sdf file
    from a txt file where i have a polyline and coordinate of every point
    there is someone function for this question
    thanks Giovanni
    Please use plain text.
    *Andy Morsell
    Re: append new objects to sdf file
    06-14-2005 08:35 AM in reply to: *Giovanni
    I would recommend you look at the .SDL format file which is the ASCII
    equivelent of a .SDF. You may be able to manipulate (manually or
    programatically) your text file to get the information into the required
    format. You can then use SDFLoader to convert the .SDL to .SDF. There is a
    switch with SDFLoader to append to the file rather than overwrite it.
    Andy Morsell, P.E.
    Spatial Integrators, Inc.
    http://www.SpatialGIS.com
    "Giovanni" wrote in message
    news:4873961@discussion.autodesk.com...
    hi
    thanks Giovanni
    Distinguished Contributor
    06-14-2005 08:54 AM in reply to: *Giovanni
    You could use the SDF COM Toolkit to accomplish this. I believe the Help for the Toolkit has examples to do this. If you get stuck just ask for help.
    Scott
    *Giovanni
    06-15-2005 02:28 AM in reply to: *Giovanni
    thanks very much
    Giovanni
    "Andy Morsell" ha scritto nel messaggio
    news:4874369@discussion.autodesk.com...
    Andy Morsell, P.E.
    hi
    thanks Giovanni
    *Giovanni
    06-15-2005 02:57 AM in reply to: *Giovanni
    thanks very much
    Giovanni
    ha scritto nel messaggio news:4874385@discussion.autodesk.com...
    help.
    Scott
