• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    bsheehy
    Moving from Open Source to Enterprise
    226 Views, 1 Replies
    02-11-2011 06:13 AM
    If I start developing using the Open Source MapGuide version and then later decided to use the Enterprise version can i use the exact same code and setup?
    Please use plain text.
    Re: Moving from Open Source to Enterprise
    04-26-2011 12:24 PM in reply to: bsheehy
    Sure, just make sure you create the MGP file and you update your code to use the correct ini file.  It is actually easier moving from OpenSource to Enterprise than the other way around.
