• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    Valued Contributor
    Mobile viewer Extension for Map Server Infrastructure
    960 Views, 1 Replies
    06-26-2012 08:22 AM
    When we use the Map Server Infrastructure, Does it matter to select Ajax viewer or Fusion Viewer?  Does Fusion will load normally on a mobile device? How can I make the Mobile viewer extension work? Thank you
    Please use plain text.
    ADN Support Specialist
    Re: Mobile viewer Extension for Map Server Infrastructure
    08-27-2012 02:07 AM in reply to: swimming123
    For mobile devices, it is recommended to use MobileViewer, which is much lighter than Fusion Viewer, please refer to this blog to check whether it helps or not: http://adndevblog.typepad.com/infrastructure/2012/06/creating-custom-control-for-mobile-viewer-of-ai...
    Daniel Du
    Developer Technical Services
    Autodesk Developer Network
