• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    Active Contributor
    JSP, Debugging, Eclipse
    71 Views, 1 Replies
    04-16-2008 09:10 AM
    Hi Developers,
    using MG2008Enterprise, Tomcat and JSP-Installation.
    I installed some own JSP files and access to own Java classes in a *.jar file - everything is working fine.
    Question: How can I debug that application using Eclipse (3.2.0)?
    The MG Server is running on a seperate machine. Where do I have to start Eclipse environment, on my dev-machine or on server? I tryed on server, there I get the message, that ports (8080,8009) for Server are required. If I stop the MG tomcat server, then debugging is starting, but environment shows unresolveable token, as
    <%@ page import="javax.servlet.jsp.*" %>
    or
    getServletContext()
    Any hints on topic debugging JSP, Java in MGE2008 would be appreciated. Thank you!
    Peter
    Please use plain text.
    Active Contributor
    Re: JSP, Debugging, Eclipse
    04-16-2008 09:14 AM in reply to: DEDE1166
    the invisible token in first message is a import directive for javax.servlet.jsp.*
