Autodesk MapGuide Developer
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Install MGE 2009 to CentOS 4.4
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
69 Views, 0 Replies
05-19-2008 08:45 PM
I got the error as following: Anyone knows which lib I need to install first? Thanks
Treo
-bash-3.00# rpm -ivv *.rpm
D: ============== mapguideenterprise2009-webextension-2.0.0.3202-1.i 386.rpm
D: Expected size: 208155602 = lead(96)+sigs(180)+pad(4)+data(208155322)
D: Actual size: 208155602
D: mapguideenterprise2009-webextension-2.0.0.3202-1.i 386.rpm: MD5 digest: OK (4d9dade3122e3ee0a9ed16ad545900b7)
D: added binary package [0]
D: found 0 source and 1 binary packages
D: unshared posix mutexes found(38), adding DB_PRIVATE, using fcntl lock
D: opening db environment /var/lib/rpm/Packages create:cdb:mpool
rivate
D: opening db index /var/lib/rpm/Packages rdonly mode=0x0
D: locked db index /var/lib/rpm/Packages
D: ========== +++ mapguideenterprise2009-webextension-2.0.0.3202-1 i386/linux 0x1
D: opening db index /var/lib/rpm/Depends create mode=0x0
D: opening db index /var/lib/rpm/Basenames rdonly mode=0x0
D: opening db index /var/lib/rpm/Pubkeys rdonly mode=0x0
D: read h# 186 Header sanity check: OK
D: ========== DSA pubkey id a53d0bab443e1821
D: read h# 200 Header V3 DSA signature: OK, key ID 443e1821
D: Requires: /bin/sh YES (db files)
D: opening db index /var/lib/rpm/Providename rdonly mode=0x0
D: Requires: /usr/bin/perl NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: /usr/bin/perl
D: Requires: libACE.so.5.4.0 YES (added provide)
D: Requires: libCsmap.so.1 YES (added provide)
D: Requires: libMgFoundation.so.7 YES (added provide)
D: Requires: libMgGeometry.so.7 YES (added provide)
D: Requires: libMgHttpHandler.so.7 YES (added provide)
D: Requires: libMgMapGuideCommon.so.7 YES (added provide)
D: Requires: libMgMdfModel.so.7 YES (added provide)
D: Requires: libMgMdfParser.so.7 YES (added provide)
D: Requires: libMgPlatformBase.so.7 YES (added provide)
D: Requires: libMgWebApp.so.7 YES (added provide)
D: Requires: libapr-1.so.0 YES (added provide)
D: Requires: libaprutil-1.so.0 YES (added provide)
D: read h# 199 Header V3 DSA signature: OK, key ID 443e1821
D: Requires: libc.so.6 YES (db provides)
D: Requires: libc.so.6(GLIBC_2.0) YES (db provides)
D: Requires: libc.so.6(GLIBC_2.1) YES (db provides)
D: Requires: libc.so.6(GLIBC_2.1.2) YES (db provides)
D: Requires: libc.so.6(GLIBC_2.1.3) YES (db provides)
D: Requires: libc.so.6(GLIBC_2.2) YES (db provides)
D: Requires: libc.so.6(GLIBC_2.2.3) YES (db provides)
D: Requires: libc.so.6(GLIBC_2.3) YES (db provides)
D: Requires: libc.so.6(GLIBC_2.3.2) YES (db provides)
D: Requires: libc.so.6(GLIBC_2.3.3) YES (db provides)
D: read h# 202 Header V3 DSA signature: OK, key ID 443e1821
D: Requires: libcom_err.so.2 YES (db provides)
D: Requires: libcrypt.so.1 YES (db provides)
D: Requires: libcrypt.so.1(GLIBC_2.0) YES (db provides)
D: read h# 241 Header V3 DSA signature: OK, key ID 443e1821
D: Requires: libcrypto.so.4 YES (db provides)
D: Requires: libcurl.so.3 NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: libcurl.so.3
D: Requires: libdl.so.2 YES (db provides)
D: Requires: libdl.so.2(GLIBC_2.0) YES (db provides)
D: Requires: libdl.so.2(GLIBC_2.1) YES (db provides)
D: read h# 113 Header V3 DSA signature: OK, key ID 443e1821
D: Requires: libexpat.so.0 YES (db provides)
D: Requires: libexslt.so.0 NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: libexslt.so.0
D: read h# 196 Header V3 DSA signature: OK, key ID 443e1821
D: Requires: libgcc_s.so.1 YES (db provides)
D: Requires: libgcc_s.so.1(GCC_3.0) YES (db provides)
D: Requires: libgcc_s.so.1(GLIBC_2.0) YES (db provides)
D: Requires: libgcrypt.so.11 NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: libgcrypt.so.11
D: Requires: libgpg-error.so.0 NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: libgpg-error.so.0
D: read h# 187 Header V3 DSA signature: OK, key ID 443e1821
D: Requires: libgssapi_krb5.so.2 YES (db provides)
D: Requires: libidn.so.11 NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: libidn.so.11
D: Requires: libjpeg.so.62 NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: libjpeg.so.62
D: Requires: libk5crypto.so.3 YES (db provides)
D: Requires: libkrb5.so.3 YES (db provides)
D: Requires: liblib_json.so YES (added provide)
D: Requires: libm.so.6 YES (db provides)
D: Requires: libm.so.6(GLIBC_2.0) YES (db provides)
D: Requires: libm.so.6(GLIBC_2.1) YES (db provides)
D: Requires: libnsl.so.1 YES (db provides)
D: Requires: libpng12.so.0 NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: libpng12.so.0
D: Requires: libpthread.so.0 YES (db provides)
D: Requires: libpthread.so.0(GLIBC_2.0) YES (db provides)
D: Requires: libpthread.so.0(GLIBC_2.1) YES (db provides)
D: Requires: libpthread.so.0(GLIBC_2.1.1) YES (db provides)
D: Requires: libpthread.so.0(GLIBC_2.2) YES (db provides)
D: Requires: libpthread.so.0(GLIBC_2.3.2) YES (db provides)
D: Requires: libresolv.so.2 YES (db provides)
D: Requires: libresolv.so.2(GLIBC_2.0) YES (db provides)
D: Requires: libresolv.so.2(GLIBC_2.2) YES (db provides)
D: Requires: librt.so.1 YES (db provides)
D: Requires: librt.so.1(GLIBC_2.1) YES (db provides)
D: Requires: libssl.so.4 YES (db provides)
D: read h# 220 Header V3 DSA signature: OK, key ID 443e1821
D: Requires: libstdc++.so.6 YES (db provides)
D: Requires: libstdc++.so.6(CXXABI_1.3) YES (db provides)
D: Requires: libstdc++.so.6(GLIBCXX_3.4) YES (db provides)
D: Requires: libtiff.so.3 NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: libtiff.so.3
D: Requires: libungif.so.4 NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: libungif.so.4
D: Requires: libuuid.so.1 YES (db provides)
D: Requires: libxerces-c.so.27 YES (added provide)
D: read h# 77 Header V3 DSA signature: OK, key ID 443e1821
D: Requires: libxml2.so.2 YES (db provides)
D: Requires: libxslt.so.1 NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: libxslt.so.1
D: read h# 13 Header V3 DSA signature: OK, key ID 443e1821
D: Requires: libz.so.1 YES (db provides)
D: Requires: perl >= 0:5.004 NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: perl >= 0:5.004
D: Requires: perl(AnyDBM_File) NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: perl(AnyDBM_File)
D: Requires: perl(Fcntl) NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: perl(Fcntl)
D: Requires: perl(strict) NO
D: package mapguideenterprise2009-webextension-2.0.0.3202-1.i 386 has unsatisfied Requires: perl(strict)
D: Requires: rpmlib(CompressedFileNames) <= 3.0.4-1 YES (rpmlib provides)
D: Requires: rpmlib(PayloadFilesHavePrefix) <= 4.0-1 YES (rpmlib provides)
D: opening db index /var/lib/rpm/Conflictname rdonly mode=0x0
D: closed db index /var/lib/rpm/Pubkeys
D: closed db index /var/lib/rpm/Depends
D: closed db index /var/lib/rpm/Conflictname
D: closed db index /var/lib/rpm/Providename
D: closed db index /var/lib/rpm/Basenames
D: closed db index /var/lib/rpm/Packages
D: closed db environment /var/lib/rpm/Packages
error: Failed dependencies:
/usr/bin/perl is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
libcurl.so.3 is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
libexslt.so.0 is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
libgcrypt.so.11 is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
libgpg-error.so.0 is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
libidn.so.11 is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
libjpeg.so.62 is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
libpng12.so.0 is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
libtiff.so.3 is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
libungif.so.4 is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
libxslt.so.1 is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
perl >= 0:5.004 is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
perl(AnyDBM_File) is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
perl(Fcntl) is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
perl(strict) is needed by mapguideenterprise2009-webextension-2.0.0.3202-1.i 386
D: ========== recording tsort relations
D: ignore package name relation(s) [0] libtermcap -> bash
D: ignore package name relation(s) [1] modutils -> vixie-cron
D: ignore package name relation(s) [2] ypbind -> yp-tools
D: ignore package name relation(s) [3] ghostscript-fonts -> ghostscript
D: ignore package name relation(s) [4] libgnomeprint15 -> gnome-print
D: ignore package name relation(s) [5] nautilus -> nautilus-mozilla
D: ignore package name relation(s) [6] tcl -> postgresql-tcl
D: ignore package name relation(s) [7] arts -> kdelibs-sound
D: ignore package name relation(s) [8] pango-gtkbeta-devel -> pango-gtkbeta
D: ignore package name relation(s) [9] XFree86 -> Mesa
D: ignore package name relation(s) [10] compat-glibc -> db2
D: ignore package name relation(s) [11] compat-glibc -> db1
D: ignore package name relation(s) [12] pam -> initscripts
D: ignore package name relation(s) [13] initscripts -> sysklogd
D: ========== tsorting packages (order, #predecessors, #succesors, tree, depth)
D: 0 0 0 0 0 +mapguideenterprise2009-webextension-2.0.0.3202-1
-bash-3.00#
Treo
-bash-3.00#
