• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    Valued Contributor
    Error for single layer size is 1 G
    937 Views, 3 Replies
    05-23-2012 01:04 PM
    Hi there,
    When I load shp file which is bigger than several hundreds of MB, I found MapGuide always shows error. What solution for this issue? Thank you.
    Please use plain text.
    Re: Error for single layer size is 1 G
    05-23-2012 07:55 PM in reply to: swimming123
    Are you using Load Procedures? They aren't really meant for loading files of this size.
    For files of this size you should consider using aliases. Then you just create Feature Sources that point to your aliased SHP files instead.
    - Jackie
    Valued Contributor
    05-23-2012 09:24 PM in reply to: jackie.ng
    What if I load the data to PostGIS first. Then I can create create Feature Source that point to the database?
    05-23-2012 10:32 PM in reply to: swimming123
    Sure that works, whatever suits you. I am simply saying loading spatial data with Load Procedures is not suitable for really large files.
    - Jackie
