• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    Member
    grand_duck
    Error : DBEnv::open: DB_RUNRECOVERY
    501 Views, 3 Replies
    08-17-2011 01:46 AM
    I received a stange error message, when i'm connecting to my site (running with Map Server 2012).
    Error:
    An exception occurred in DB component. DbEnv::smileysurprised:pen: DB_RUNRECOVERY: Fatal error, run database recovery.
    Source:
    OSGeo.MapGuide.MapGuideCommon.
    Has someone already had this message ?
    I don't know, what to do.
    Best Regards.
    Duck.
    Please use plain text.
    Re: Error : DBEnv::open: DB_RUNRECOVERY
    10-03-2011 04:46 AM in reply to: grand_duck
    Hi Duck,
    I have a server exactly with the same problem. In my case, the error occurs in a call to CreateSession.
    Did you find any solution?
    Member
    grand_duck
    10-04-2011 01:25 AM in reply to: migueaguilera
    I've received a information from Autodesk:
    Another suggestion you can have a try is : increate the value of SessionRepositoriesLimit
    Please refer to the AIMS2012 readme doc -> Other Updates and Enhancements ->  Updates in serverconfig.ini.
    SessionRepositoriesConfig          = FilePerSession
    SessionRepositoriesLimit           = 200
    Above ones are default setting for AIMS2012. Once the number of sessions reaches the Upper Limit, you may encounter the Fatal Error below.
    For the moment, I changed the filePerSession by SingleFile, it seems to work, in my log, since 1 day, i don't found any DB_RUNRECOVERY.
    But now, I have an another problem, the size of the repositorie increases quickly  :smileyfrustrated:
    In my repositories, folder site, I see  log.0000x  created every 2 or 4 minutes, and i don't know why ??
    Any ideas ?
    10-04-2011 02:55 AM in reply to: grand_duck
    Thx for the info Duck.
    I am performing several tests on my server. I'll tell you if I have good news and solve the problem.
