• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    Active Member
    Db::put: DB_LOG_BUFFER_FULL: In-memory log buffer is full
    791 Views, 2 Replies
    10-25-2012 10:51 AM
    Our map has more than 400 layers, and I see this errors very often from error log file:
    Error: An exception occurred in DB component.
    Db::smileytongue:ut: DB_LOG_BUFFER_FULL: In-memory log buffer is full
    Is anyway to set DB_LOG_BUFFER.
    we use AIMS 2012
    Autodesk Infrastructure Map Server (Version 2.3.0.5801)
    Autodesk Infrastructure Map Viewer (Version 2.3.0.5801)
    I tried to reduce some layers and see less this error on log file.
    Any solution?
    thanks!
    Nick
    Please use plain text.
    Valued Mentor
    Re: Db::put: DB_LOG_BUFFER_FULL: In-memory log buffer is full
    10-31-2012 08:51 AM in reply to: nick_xu
    In the serverconfig.ini in the BIN folder,  I have modified my LogBufferSizes:
    SessionLogBufferSize = 20
    LibraryLogBufferSize = 50
    Active Member
    10-31-2012 09:45 AM in reply to: gluckett
    I'm using AIMS 2012 and can't find these 2 entries from serverconfig.ini
    anything can be configured for these [DBEnvironmentProperties] for AIMS 2012?
    thanks!
