• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk MapGuide Developer
    Valued Contributor
    Could not load 'MapGuideDotNetApi' warning message
    907 Views, 3 Replies
    09-17-2012 07:40 AM
    When I start to do customization for AIMS using VS2010 .NET4.0, I copy the .dll file to my project folder, add reference to5 OSGeo***.dll files.  I got the warning messageis as follows:
    Warning           C:\Altus\AltusWebMap\AltusWebMap\Default.aspx: ASP.NET runtime error: Could not load file or assembly 'MapGuideDotNetApi' or one of its dependencies. An attempt was made to load a program with an incorrect format. C:\Abc\AbcWebMap\AbcWebMap\Default.aspx         1          1          AbcWebMap
    How to fix this?  Is this the problem that cause my redline not working? Thank you.
    Please use plain text.
    Re: Could not load 'MapGuideDotNetApi' warning message
    09-17-2012 07:50 PM in reply to: swimming123
    You need to make sure your IIS application pool assigned to your web application is running at the same bit-ness as your version of AIMS/MapGuide
    - Jackie
    Valued Contributor
    09-18-2012 07:28 AM in reply to: jackie.ng
    IIS Application pool is 64 bits, AIMS2013 is also 64bits, but my visual studio 2010 is 32 bits. It also matters,right?
    09-18-2012 09:00 PM in reply to: swimming123
    If you're debugging with Visual Studio's built-in web server (or IIS express), it's probably a 32-bit process, which is why it can't load your 64-bit MapGuide assemblies.
    Try setting up a virtual directory in IIS for your MapGuide/AIMS application (assigned to the same application pool as MapGuide/AIMS) and open that virtual dir with Visual Studio (probably need UAC elevation). This should let you debug with IIS proper and have all the bitnesses be the same.
    - Jackie
