Autodesk MapGuide Developer
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Could not load 'MapGuideD otNetApi' warning message
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When I start to do customization for AIMS using VS2010 .NET4.0, I copy the .dll file to my project folder, add reference to5 OSGeo***.dll files. I got the warning messageis as follows:
Warning C:\Altus\AltusWebMap\AltusWebMap\Default.aspx: ASP.NET runtime error: Could not load file or assembly 'MapGuideDotNetApi' or one of its dependencies. An attempt was made to load a program with an incorrect format. C:\Abc\AbcWebMap\AbcWebMap\Default.aspx 1 1 AbcWebMap
How to fix this? Is this the problem that cause my redline not working? Thank you.
Re: Could not load 'MapGuideD otNetApi' warning message
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You need to make sure your IIS application pool assigned to your web application is running at the same bit-ness as your version of AIMS/MapGuide
- Jackie
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
IIS Application pool is 64 bits, AIMS2013 is also 64bits, but my visual studio 2010 is 32 bits. It also matters,right?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you're debugging with Visual Studio's built-in web server (or IIS express), it's probably a 32-bit process, which is why it can't load your 64-bit MapGuide assemblies.
Try setting up a virtual directory in IIS for your MapGuide/AIMS application (assigned to the same application pool as MapGuide/AIMS) and open that virtual dir with Visual Studio (probably need UAC elevation). This should let you debug with IIS proper and have all the bitnesses be the same.
- Jackie
